Hi guys, this look like a good site to ask, I have this error sometimes and I was able to solve it by restarting my console but from time to time it happens. Is there any quick fix for this problem?
If Wii gives Disc Read Error, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide.
Be sure to make sure the disc itself is clean and free of scratches. If the disc does have scratches on it, you may want to invest a few dollars on a scracth repair kit.
Here's a few things to try, straight from Nintendo's website:
http://www.nintendo.com/consumer/systems...
Hope this rectifies your issue.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
172
Your drive could be defective, I would recommend calling Nintendo. I hear they have great customer support. You might also have a dirty drive you could try getting a can of compressed air and blowing it in there. If you do that blow the air in small bursts, don't hold the trigger down, the cold could ruin your Wii even more.
We just got our Wii and keep getting the same disc read error. Sometimes it takes a few minutes to get the system to read the disc, is this normal?
Our fan sounds horrible on our WII. Now it says "an error has occured, please turn console off and refer to the manule." Does this mean our system is shot? Thanks Candy
