Pentax Optio E10 Digital Camera Logo
Naomi Link Posted on Jul 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card locked!??
I used my Pentax Optio E10 tonight and took the memory card out to put the pictures on the computer, put the card BACK into the camera, turned it on to delete the pictures, and it now says Card Locked on the screen. It won't let me take pictures or do anything at all. How do I UNLOCK the card when I don't know how it got locked in the first place?
  • Anonymous Nov 03, 2008
    i had taken pictures about a week ago and put them on my computer then when i turned y camera on the screen read card locked what do i do?
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jul 05, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027612
Points
5636
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
2answers
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Hi - I am trying to connect to my computer to print pictures of my Pentax Optio E10, but I am not getting a recognition from the computer when I plug my camera in.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Installation of pentax optio E10
You don't need to install the camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
7helpful
My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Pentax Optio E10
You don't need any software.
8helpful
2answers
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
