Intermittent problem. At power-up, can hear a soft high-pitched whine for several seconds .. one or two times. Usually,audio (only) will come on. Then steady red status light. Will then be fine for days. Power plug and/or "system" resets seem to have little effect. Now out of warranty. Also, how do I bring up "error codes" for this beast. I've changed the lamp once myself. Thanks
SOURCE: Red Status Light
Hi we have a 52 inch mitsubishi high definition tv and ours did the same thing,we had a repair man out here and he said it was the engine in the tv which we never knew tv's had engines so i contacted mitsubishi cause we didn't take a entended warranty and told them that it was not even 3 yrs old and they should stand up to there products and they did they paid for the part which was 600 dollars and we had to pay for labor....we thought it was the light to and ordered one and it wasn't it was doing the same thing yours did .....
SOURCE: mitsubishi wd-65831 one night worked fine next day nothin..
i.m having problem were to buy a Mitsubishi lamp cartridge TYPE 915P028010. how much it cost.
SOURCE: my wd-62825g wont power up.
If you have never replaced the Lamp ,Then it will be the Lamp Part number is 915PO29910 Mats Elec tronics has them for $99.00 1-800-628-1118
Keep in mind on DLPs -Lamps only last between 5000 up to 8000 playing hours .
Here is the most common things that go bad Lamp,Lamp Fan
Ballast Board that turns Lamp on and Bad Capacitors on the power supply Board Bad capacitors will be swollen or puffed up on Top Most of the time other wise they become leaky and will not hold the voltage charge.
If you should need anymore help just let me know!
Goole to this website for Parts Listing for your Model number
Encompass Parts Distrubtion
SOURCE: My WD-52525 will not produce
Steady red lamp light indicates lamp did not turn On and we need to narrow down the reason, there is error code operational check procedure, please follow below info (taken from related service manual) to get error code and let me know to diagnose possible cause of problem in tv.
Error Code Operational Check
Note: The TV must be in "Shut Down" and not manually switched Off, to perform the Error Code Operational Check, let lamp light lit.
Press the front panel "DEVICE" and "MENU" buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is "32", the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
Post here your error code finding to provide you more info.
Thanks.
SOURCE: My mit wd52525 is dead. Once
Lets access the "Error Code Operational Check" to determine where the fault came from.
Note: The TV must be in "Shut Down" and not manually switched Off, to perform the Error Code Operational Check.
When the TV is switched Off, the code automatically resets to "12" No Error.
Let me know the error code to assist you further.
Jdvillanueva
your problem is in flyback or high voltage section failure.
