All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
As you have got this problem and cell is only 6 months old. Pls get it replaced under warranty.
Do carry the invoice with date to the service center.
Alternatively also check the charger, as sometime the cell shows charging due to inserting the pin and a low current passes through but still charger is faulty. Try using some other charger and then go ahead.
Regads,
Richee
Take some time to rate me if it works well.
