Hello Sir, i have gm338 vhf transmitting and receiving all ok but i am not getting audio, i check sound amplifier ic that is ok speaker also ok. volume control also ok. how can i solve this problem
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
This is a front end issue that has to be remedied by a radio tech or the factory. The front end is the receiver and it takes special tools and equipment to test and calibrate it correctly,, The only thing you can do is check the ICOM page to see where it can be serviced.
Hello
Either your tVs speaker of its audio output IC has damaged. Check the TV by onnecting its audio out jack to any other audio source, like amplifier or so, and see whether there is sound output comes through the outer source or not. If there is sound from the amp; and no sound output from the TV, check the speaker first. If it is OK, replace the audiou output IC. If there is no sound through outer amplifier, the audio detectcion section inside your TV is faulty. You must have a thorough knoledge and skill to repair it. OK.
Hello
Either your TVs speakers or its output IC may have damaged. To confirm it, just up the volume of your tV, and try to hear the sound if any. If it feels like dostorted or very low-hard to hear, the speakers must be suspected. If there is no sound signal at all, output IC should be damaged. To confirm whether the sound detecting section is Ok, just connect your TVs audio output sockets at the rear of your TV with an amplifier or so, and rise the amplifier voluem, to get sound through it. If you get sound in this way, make sure that the above daid two items. Fist check the speaker, by connecting an external speaker in place and listen to it. If it also doesn't get the result, surely the output IC of your TV has damaged, and should be replaced with same type and number. OK.
If there is no audio output from your tv, either your TVs speaker or its audio output IC has damaged. You just check it with an earphone/headphone, if there is an earphone or headphone socket in front panel of your TV. If there is sound from the headphone/earphone, and not from the speaker, means the speaker has damaged. You have to replace it with same type and number. Just check your set's audio out socket, if any provided, connet it to any external audio sourse, like amplifier or so, and check whether there is sound output from it. If not, your Tv/combos' sound processing IC inside has some trouble.
most common fault is related to sound output IC or speaker itself. If speaker is found OK, go to the sound output section. This section can be easly located as speaker wire goes to that section, and follow it. Before replacing the IC, check its leads for any loose or bad soldering. i advice you to resolder all the terminals of that IC, by applying a little more solder, without making any solder bridge loose contacts between them. If this does not helps, replace the IC with an identical type and number. OK.
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
your receiver left fuse is blown, check if it has a user fuse at the back. or
your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
