Have a 100 hundred gallon tank and 200,000 btu, running out of enough hot water, how much water per cycle, and does this washer have heaters in it. worked fine for 8 months and now have a problem. We are contractors and tring to figure this one out. Thanks
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
SOURCE: Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
SOURCE: EMPIRE MDL 215 VENTID NOT HOT ENOUGH
Sal,
the gas pressure test should be done. Propane should have an outlet(heater side of the regulator)of 7 inches of water column. the inlet side has to be higher than that to supply it the proper pressure. Also the heater should have been converted to LP with proper orfices and springs
SOURCE: I have a jackson Low Temp single door model.. I
size alone does not matter, its all about the recovery time
The manufactor requires 100 gallon tank and 157,000 btu it is a high recovery Lochinvar boiler
