Question about Korg ESX1 Electribe SX production station (with )
Cannot format or reload factory presets after it stopped working
My KORG ESX-1 stopped working. Although the knobs and functions seem to still be working, no sound comes out of it. Apparently all the presets were deleted (for whatever reason). I tried to rebbot the system (using the step-by-step instructions in the manual) but no good. I then purchased a SmartMedia/ XD car to try to reload the factory presets (from the KORG website), but it seems that it cannot be formatted (keep getting the message 'FORMAT ERROR'). As for now, I cannot reload the preset samples and loops (or do anything for that matter). Can anyone find a solution to this problem please? That'd be much appreciated. Cheers!
  • Pedro Campos Jan 16, 2013
    Cheers for the help! However, the main problem is that the card cannot be formatted on the ESX-1 (I keep getting the 'FORMAT ERROR' message). Does that have to do with the fact that I'm using a SmartMedia/ XD card adapter? I also have a SmatMedia reader (connected via USB to my coimputer). I can download the files to the card no problem, but since it is not formatted on the ESX-1 it cannot be read. It's quite frustrating to be honest (especially after all the hassle I went through, buying adapters and cards). All the best!
  • goodvibratio Feb 21, 2019
    I am having the same issue. did you ever figure out how to fix it ?
  • 114 Answers
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Posted on Jan 14, 2013
  • Seanzilla Jan 16, 2013
    I would suggest going to a store and getting another SmartMedia card to try. Heck, but a really cheap one (4GB), put it in the unit, and try formatting it then. The other option is to format the card directly from your computer FIRST. (1) put the card in your reader (2) click on "My Computer" (3) right-click on card and select "Format" (4) select "Restore Device Defaults." Put back into KORG unit and try formatting again. Just be sure that the card is not in "lock" position either. Good luck!!
4 Suggested Answers
SOURCE:
SOURCE: os system not loaded! hard drive was totally formated. PA800
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
Posted on Jan 17, 2010
  • 5603 Answers
SOURCE: I have a old (but almost unused) Korg d1200
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Posted on Jun 18, 2011
  • 5603 Answers
SOURCE: I have a1980 Korg CX3. Last night at the gig It
This is likely a power supply problem. It is important that all interconnected equipment be powered by the same receptacle OR source or isolation such as DI's be used for system safety.
Posted on Jan 30, 2011
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
My Korg TR 61 some buttons doesnt work.
It's more likely to be a cleanning issue. Really, it's almost as easy to replace the switches as to clean them. Parts are available on ebay for very little money.
Sep 21, 2015 | Korg Music
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Factory preset
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 07, 2015 | Korg Music
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Can somebody post the PA800 Diagnostic Menu Command
The details are highly confidential and have only ever been released to engineers under Non Disclosure Agreements, who work closely with Korg in the design process. If anyone tries to tell people about it on the forum then a breach of an NDA has occurred and whoever did it could be sued by Korg. The person posting those details could have their account on the forum suspended.
Please understand that there are very good reasons why Korg want to keep those details confidential. The functions were designed for use in the factory when the keyboards are manufactured. Two of the functions can completely wipe the internal SSD and the boot EPROM rendering the complete keyboard unusable. One of the circuit boards would have to be returned to a factory for the chips to be re-initialized using specialist hardware plugged directly into the CPU board. The necessary hardware to re-initialize the SSD and Boot EPROM is not even available to Korg service centers.
If you are someone who has discovered the way to access the system diagnostic menus, then there is a high risk you will completely trash your Pa2x/ Pa800 etc, turning it into a "brick" that will no longer be capable of reloading the OS or factory data. Korg representatives have said to us several times that damage caused in this way is NOT covered by warranty. If two of the functions in the system diagnostics menus are used, then to get the keyboard working again, service centers will have to replace the complete "main board". This is the board which contains the SSD and boot ROM chips. You are looking at a repair cost of over $800 plus shipping.
Oct 24, 2014 | Korg Pa800 Synthesizer
I connected it to 220v, but the power supply is the US one (120V). Is there a chance that my ESX still works?
• Power Supply should be checked first by a multimeter
then the ESX will follow.
other option:
• Borrow a working power supply adaptor one from a friend,
just to determine if it is the ESX , the power supply or
both ( I just hope not )
Once determined , you can either repair or replace
the AC/AC power supply
Let us know how it goes
Sep 14, 2012 | Korg ESX1 Electribe SX production station...
How to reset the korg m50
PLEASE HELP ME... this appeared in my KORG M50.. says. LOADING OS FAILED..... Is ther a solution to this...
Jan 23, 2012 | Korg M50 88 Note Workstation
Hello there how can i reset my korg kaossilator pro please help i cant get it back to factory settings
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
Jan 10, 2011 | Korg Kaossilator Pro Tabletop Synthesizer
Korg ESX1 Electribe SX production station (with ) Logo
188 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
