Question about Sony STR-DE335 Receiver
"Protect" Flashing Playing a CD one day and all of a sudden the music stops and the display shows "Protect" flashing. I tried resetting the receiver and this did not work. What is the next step to fix the problem.
  • 1 more comment
  • dj_rob_knigh Feb 28, 2009
    protect flashing i dont know how to fix it HELP!!!!
    STR-DE335 even when i unplug the speakers the protect flashing
    do i need to tack it to a repair shop or is there some thing i can do to fix it?
  • ukball1 Apr 30, 2009
    Locked in the PROTECT mode, the manual says to unplug and this will reset. That did not work. Is there a hard reset, pushing several buttons together that will reset????
    If it would be a fuse, where might that be located?
  • 4,234 Answers
In all likelyhood, one or more output transistors have failed. Please confirm your model as STR-DE335 and I'll post the probable parts that need to be checked.
Dan
Posted on Jan 22, 2009
  • Mike Webb Dec 01, 2011
    I am in the same situation as this person and I can confirm that this is my model of receiver. I would appreciate very much a list of parts to check. THANK YOU IN ADVANCE!
SOURCE:
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
My car stereo flashes the word "PROTECT"
If this happened while playing music at a little higher volume, you must check the speakers for short in coils. disconnect the speakers to see if the protect condition changes, if so check the speakers and wiring. If not then you must have blown up the output IC or a power shorting within the set. You will have to remove the pcb disconnect the power to the output IC to confirm the fault. Helpful I hope. Good day
Jul 06, 2010 | Kenwood KDC-MP235 CD Player
I have a Sony receiver STR-DG510. I was playing music through the receiver when it suddenly stopped and displayed/flashed protect. After unplugging everything and trying a different power outlet it still...
Most likley it is a bad channel. Needs output transistors and a couple of resistors. or it may need a pre-amp voltage ic.
Not a repair for your average do it yourselfer.
Jun 30, 2010 | Audio Players & Recorders
Display flashing on my deh-p6500
It has what is called reverse mode which flashes to protect the display to turn feature off please follow these steps.
Press the 5 numbered button when power to this unit is turned off while the ignition switch is set to acc or on will cancel the reverse mode and stop the flashing. Hope this helps.
Jan 06, 2010 | Pioneer DEH-P6500 CD Player
Kenwood KDC-MP235 CD player flashes Protect
check for shorts in your speaker wiring..
Mar 25, 2009 | Kenwood KDC-MP235 CD Player
I have installed the receiver and it played the music from my USB flash drive very well, but few days ago it stopped playing (displaying NA files)...then it's not recognizing that the flash drive is...
JUST PRESS THE RESET BUTTON, SITUATED NEXT TO THE USB PLUG.
IF ALL THE CONNECTIONS WERE OK, IT SHOUD REINITIATE THE KDC-MP438U AS PAGE 3
OF THE MANUAL. YOU WILL HAVE TO READJUST THE CLOCK.
CLAUDE
Jan 12, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Dec 29, 2008 | Onkyo TX-SR602 Receiver
My boombox is displaying the word "Protect" in the display. ???
The protect message indicates that there is a problem with the final stage of the amplifier section. This unit will require repair as a reset will not clear this. There is an audio amp IC inside that needs to be replaced. Figure on about $15 or so for the part.
Dan
Dec 09, 2008 | Sony Boom Box With CD Player & Cassette...
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Sony STR-DE335 Receiver Logo
726 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
