To enter service mode on biz hub c 500 what is the key order?
My cyan ran out I have an error code of sc 45-20 and I want to fix it it starts up then the code pops up I turn off then recycle but it will not run long enough to add the toner without the code poping up?
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
1 Press the "Clear Modes" button. This button will be on the main panel.
2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
5 Turn off the main power. The main power button will be located on the side or front of the copier.
6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
you can try to reset the code by entering into service mode, just enter into service mode and then shut down the machine by the main switch and then turn it on after 30 seconds.
For to enter into service mode press the following keys in the next order:
press the yellow key ; then press 1-0-7 and then press the red key and hold it pressed until on the screen do not show service mode.
If after this again the machine gives fusing error, it means that you have problem some part in the fusing unit. possible is the termistors or the teromstats
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
YOU CAN RE-TONE THE MACHINE BY ENTERING SERVICE MODE SELECTING IMAGE PROCESS ADJUSTMENT AND TCR SUPPLY SELECT THE COLOUR THAT IS DEFICIENT AND RUN THE SUPPLY JUST ONCE. BEFORE YOU DO THIS CHECK THAT THE SEALING STRIP ON THE TONERS HAS COME AWAY AND NOT STUCK OVER THE HOLE HENCE STARVING THE MACHINE OF TONER.
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517 For to enter the service menu you should do the follow steps : 1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop] 2.Hold it down until service mode do not appear if not appear after 10 seconds try again. After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1". Then turn off and after 5 seconds turn it on the machine. Please replay if this do not help and write the SC code good because i cannot find the code SC517
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
