Hi can you help please we used to be able to play the pc game cars on are computer but now find we are unable to. the following error is coming up. Faulting application cars.exe, version 0.0.0.0, faulting module cars.exe, version 0.0.0.0, fault address 0x001bb41e.
It might be due to fault in computer graphics world that's not recommended for the game that makes the script working imperfectly. Glitches in a platform game may show error of invisible wall collision errors, sprite errors, freezes, image problems, and others.
So all you have to check your hardware and re-install graphics drivers can fix your problem. Also have a look to game requirements for running on PC platform and can fix your error.
If you are unable to fix this problem even if Graphic drivers are up-to-date. Then best and easy solution is to use system utility program PC Fresher
Your Dell laptop has low RAM/high CPU usage, a lot of games tend to use high CPU, so your laptop could be a little old for newer games, so you should upgrade it, or you have a lot of files on your laptop and maybe you opened to much high CPU usage programs.
Hi. It seems most of your computer hardware meet the requirements for this game. However, you do not have a separate video card. You are running on an Integrated Graphics Driver that comes with your motherboard. Most of these "default" graphics drivers do not have sufficient processing power to run newer games. I'm surprised you can still play the game tho, even at low speeds. You may have to get a new video card to play this game at full speed.
HI,
The thing is '.dll' type files are a lot of important to run any application and I think that the disk dont have it already in it so there might be a disk problem or this could be because its too old because modern versions of windows like vista, 7 or xp cannot play old games or apps. Your pc probably could play any of the modern games.
Best regards
Have you defragged the computer within 30 days?
if not, do so.
Does your "C" drive (HDD) have more than 15% of disc space left? if not, get it back to a minimun of 15%.
Do not use the computer while defragging.
Mastersage......................
okay try this
Go to your My computer icon--right click on it
properties-->hardware-->device manager
Find ur cd/dvd drive on it
Uninstall it by right clicking it (dont get scared ur system will detect it itself in next reboot and u dont need any drivers for it)
hope it will works if there is no physical damage
Please Rate ...
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link. http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
