The headset is paired to my ps3, when I enable it the blue light flashes every few seconds. Yet, I cannot hear anyone else or I cannot talk to anyone. I went into the voice changer setting to see if the mic can detect any noise, and it does not. However, when the bluetooth is connected to my phone it works perfectly. Note: I have successfully paired the device.
SOURCE: help! I've no idea!
fold the boom up, push and hold down the central button until it turns violet, open the boom and then let up on the button. The central button should stay violet without blinking. Then go through the pairing routine on your phone.
SOURCE: My Motorola h700 bluetooth will not pair
Rest assured that the drop did not cause this. There is a general problem with these H700's.
Press the multifunction button until the led turns purple. Keep it pressed in while you flip the arm open. The arm needs to be kept fully extended to keep it in pairing mode. If you succeed in positioning the arm correctly, a steady blue light will be on. If the light goes off...close the arm and try again.
While in this mode...execute the pairing procedure from your phone...it should find the H700. The default key is "0000".
SOURCE: Problem with Blackberry Pearl 8100
Open the boom on the headset and hold the button until it turns purple. Go to "Setup Bluetooth." Click "OK" when it tells you to be sure the device is in pairing mode. When the list of devices comes up, choose the H700. Enter passcode "0000."
The device will appear in your paired devices list in the "Setup BlueTooth" screen. Close the boom on the H700 then reopen it and hold the button until it turns purple. Click on the H700 in the devices list. Choose "connect."
This worked for me.
SOURCE: i have a blackberry storm
Hold down the connect button on headset
until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000".
Now the H700 will show up in the Bluetooth device list, but it will not
connect.
Put the headset in pairing mode again, this time go to the h700
listed on the phone and select connect. Now the devices will work
as normal. When you open the boom on the h700, it will connect to the phone.
