Canon PowerShot SD1100 IS Digital Camera Logo
Posted on Aug 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't my canon powershot sd1100 is camera turn on
The camera was fine the day i used it and the next day i used it but on the next day it just didnt turn on at first i thought the battery was dead but when i charged the battery it still didnt turn on. I tried to put another battery from the same time of camera and it didnt turn on. I put my battery in the other camera and it did turn on so there is nothing wrong with the battery
  • Anonymous Feb 01, 2009
    same thing
richie46
Level 3:
Top Expert:
  • Canon Master 12,962 Answers
  • Posted on Aug 28, 2017
richie46
Canon Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946176
Points
58151
So your power shot has gone south. Shame because they are really good cameras. Unless it is a very ex[pensive model repair is never cost effective.
5 Related Answers
Anonymous
  • 477 Answers
  • Posted on May 25, 2009
SOURCE: camera was working fine...all of a sudden,it would not turn on...thought maybe battery was dead,tried to recharge it,light would not go on,tried another charged battery,still would not work
This error is either a flash circuit or a lens error. One of the two need replacement.
Anonymous
  • 38 Answers
  • Posted on Jul 08, 2009
SOURCE: canon powershot sd1100 water damage..how can i
You really can't....however, there is a very small chance that it might work but you need patience though. First you need to take the battery and the casing off in order to expose the circuit board. Secondly if you can find a dehumidifier, you should run the dehumidifier and place the camera in front of it for 72hrs with no interuptions. Lastly, put the camera back together. Hope this will help. If not, the circuit board has short circuited itself and there is no possible way to replace any components.
t00nz
CameraR
  • 4738 Answers
  • Posted on Jul 31, 2009
SOURCE: my canon powershot SD1100 IS camera lcd screen
You may have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. Press the DISP button once with the camera turned on to see if that corrects the problem. If this doesn't correct it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
  • 102366 Answers
  • Posted on Feb 23, 2010
SOURCE: Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Anonymous
  • 11 Answers
  • Posted on Jun 23, 2010
SOURCE: somebody was using my canon powershot g9 and when ...
Camera likely has a common short that comes up on the G9 camera. You just need to get the camera serviced and you'll be back in business again. The site that specializes in service for the powershots is: camerasandparts.com They're amazing if you need help with one of these, that's all they deal with. The good thing with them is they do the correction so that common short never comes back again on the G9. Good luck, that's the place if you need help with a powershot model, they're excellent when it comes to service for these.
How do i puld in my canon powershot SD1100 IS in my pc?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Turned on camera (Canon PowerShot SD1100 IS) and was told that the card was locked! How did this happen and how can I unlock it?
2answers
How much does t cost?
Canon PowerShot SD1100 IS Digital Camera will cost you around $258. If you want to buy it online, you can visit this link.Thanks for using Fixya.Good Luck and have a nice day
PowerShot SD1100 IS Digital Camera: sd1100 wont connect to mac...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
1helpful
Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
Canon powershot sd1100 need to turn off flash
Press the lightning bolt button, then use cursor-left/right to select the lighting bolt in a circle with a slash through it. Full details are in the "Using the Flash" section of the manual (page 64 in my copy). If you need a manual, you may download a copy from here.
Canon PowerShot SD1100 IS not being recognized by my computer
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
