2005 Cadillac STS Logo
Andy Freed Posted on Jan 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cigaret fuse location
How can I tell which fuse is for the cigaret lighter or the location where it should be in the fuse box?
montehammons
Level 3:
  • Cadillac Master 5,531 Answers
  • Posted on Jan 10, 2013
montehammons
Cadillac Master
Level 3:
Answers
5531
Questions
Helped
1645307
Points
17401
The owner's manual would tell you. If the fuse box has a cover, it might show fuse locations.
1 Related Answer
Anonymous
  • 731 Answers
  • Posted on Mar 19, 2011
SOURCE: 2007 Cadillac EXT truck cigaret
Hi :) On the back side of the cigaret lighter there is two wires a black (- ground) and a orange (+12 volt) check to see if they are plugged in to the back of the cigaret lighter.+12 volt going to the center connector of the lighter. - ground going to the outside case.
Where is the Fuse located for a 2007 Corvette Cigarete lighter?
the fuse for the cigarette lighter is located in the fuse box under the hood. It is a 20 Amp (yellow fuse) in position #32. You can check the lid of the fuse box under the hood for a diagram to show the positions.
2answers
Cigaret lighter
cigarette lights draw considerable current flow so look in the engine compartment for a fuse of at least 25 amps.. It will probably under a plastic cover and marked cig
2answers
1helpful
2answers
Cigaret lighter dont work needto find fuse and cant
I want to change out the cigarette lighter on my 2003 Mitsubishi Montero. Is there an easy fix?
Replacing a fuse for the cigarete lighter
left hand side, underneath the steering coluum.
10helpful
3answers
Fuses
Cigaret lighter and rear window defrost
check your owners manual for the fuse location for this and replace the fuse.
7helpful
2answers
FPontiac G6 cigaret lighter fuse location
i have a pontiac g6 and i need to locate the cigarett lighter fuse box so i can replace the fuse. 2006 model
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
