SOURCE: top oven does not work...
If the oven is wired properly and correct polarity on the outlet, here is the power flow.
Power will come from the control board relay, through the ignitor, then goes to ground through the dual valve.
The resistance of the ignitor causes it to heat up, the hotter it gets the more power goes to the valve. When the amp draw gets to about 3.2 amps there is enough power for the valve to open and let the gas into the burner.
It is unusual for both the bake and broil functions to fail at the same time. They are separate circuits. The dual valve is actually 2 separate coils inside one housing.
If you have continuity through the ignitors and continuity through the valve coils, check the wiring from the valve to ground. These should be the white wires that come from the valve and connected together before going on to the main neutral connection.
Let me know what you find.
Thanks, Mike
SOURCE: Maytag MGR5775QDS oven wont heat.....
Replace the ignitor. You will need remove the bottom plate (remove the two screws back corners). And the disconnect the wiring from behind. This little part will cost you approx. $100.
SOURCE: maytag oven is not working
sounds like one of the elements may have blown.I would call manfacturer and give them year and model no.and tell them your problem they should be able to help you also any good appliance repair and parts store as well
SOURCE: The ignitor in the stove heats up, but we don't
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
SOURCE: maytag oven wont bake. stove and broiler work and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
