SOURCE: I want a solution for a Sharp AR - 287 Digital Image problem
H4-01 = Sub heater lamp abnormally low
temperature detection
If your fusing unit is old replace the whole Fusing unit.. this will solve jaming issues you might have there as well.. call an authorized service tech if your unsure of what this all means?
SOURCE: Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
SOURCE: Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor
temperature. you could remove the fuser unit and make sure these items
are clean - no build up on them. there should be a center and side
thermistor.
You can reset the error code in SIM mode by pressing
the following keys one after the other "P" "interupt" "C" "interupt"
then 14 and start/copy key. confirm if required. make sure the copier
is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
SOURCE: Error Code E7-11 on a
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
Ask for assistance if you doubt from a qualified technician and you will succeed.
