Hp laserjet 1536dnf MFP gives error -50.2 fuser error , turn off then on
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
SOURCE: Network Printer Problem
In the later HP LaserJet printers the printer has a "Mopier mode" that will provide better print performance on multiple copies. However, if you have "Mopier mode" enabled and you don't have an EIO hard disk installed, you'll get the above message.
Right click on the printer, select "Properties". There should be a "Device Settings" tab. Under that tab, make sure that "Mopier mode" is Disabled at the bottom.
The unit will still print multiple collated copies with that disabled.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
SOURCE: I Have HP Laserjet 3055
You can reseat the fuser or you will have to replace the fuser. Please note the these machines the fuser is located in the middle of the machine. Most likley it's a bad fuser.
