LG Home Applaince LG SteamDryer Series DLEX2501V Electric Dryer Logo
dee bordenave Posted on Jan 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer making weird noise after not replacing filter after usage
I cleaned out filter and forgot to replace it before reusing the dryer. It now makes a strange noise during cycle. How can this be repaired and what is the usual cost?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 249 Answers
  • Posted on Jan 10, 2013
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
249
Questions
Helped
45793
Points
519
The usual cost is about $500 - $600 if you call A&E FACTORY SERVICE
$700 - 1.000.00 if you call Appliance Unlimited
I thank you should get a all new unit instead of fixing it
  • Anonymous Jan 10, 2013
    personnel I Thank that
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 • Dryers
1helpful
My dryer WGD96HEAW1 makes vibrating and grinding noise after heats up, not in the beginning when turned on.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Feb 28, 2016 • Dryers
Making a terrible noise
its cloged or the pad behind it is burned up
My 800 kenmore series is making weird sounds and not heating like it should I cleaned the filter in and out. Lots of lint. But still weird sounds and getting worst.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2011 • Dryers
Kenmore dryer making a weird noise
sounds like a bad drum wheel,it won't do anything bad you can keep using it or replace the wheel-mike
My dryer makes a weird noise when running, kinda like the drum is rubbing against something, could that be a worn belt?
depending on the make and model of the machine the drum glides or rollers need replacing,to accomplish this you need to remove the front cover by removing toe kick panel screws and lifting up on cover,you get instructions with the glides or rollers on replacement when you buy them
Jan 23, 2010 • Dryers
2answers
I have a 99 dodge durango 5.2. I was told my fuel pump is on the drivers side of the truck near the second door. I was told it is too loud and is beginning to go out. When I drive the truck it does not...
if it's making noise then it's going out, try keeping the tank at least half full at all times until u change it to relieve stress that much gas causes it's own pressure so the pump won't have to work as hard. Yes u can reuse the housing IF the housing is not the problem in the first place.
1helpful
4answers
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Top LG Home Applaince Dryers Experts
john h
Are you a LG Home Applaince Dryer Expert? Answer questions, earn points and help others
