Hp compaq 6910p, 2.0 GHz processor, 2 GB RAM, 150 GB HDD
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
SOURCE: upgrading processor
Sell this system on eBay asnd buy a new one from Dell or HP as the price of the processor and the ram plus the installation charges will be higher than you Buy a new one with that configuration or Better
Trust me
SOURCE: nx6110 compact hp laptop freezes at the startup(HP invent)screen
just press ******* the side were the hdd is and hold it untill you see the light flashes
SOURCE: Processor upgrade
Your CPU is tied into your motherboard. Only CPUs that are compatible with your motherboard will work. You can get your motherboard model from start>programs>system tools>system information. Once you have the model # then you can start searching for the CPU options. Good Luck.
Please rate this solution.
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
SOURCE: HP HP ProBook 4510s - Core 2 Duo T5870 / 2.0 GHz -
You can only download drivers for the chip set that is in your laptop. Any other will give trouble.
Consult your manual or HP.com to be sure what is actually there.
Hope this helps
