What about 9pm to 6am????
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
SOURCE: Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
SOURCE: Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
SOURCE: Can you please explain how to set my thermostat
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
SOURCE: Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
honeywell cm921 problem with red light flashing tenp not controling boiler can any one hel
