In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Open Control Panel - Display - Settings tab then in Screen resolution move the slide to get the screen resolution 1680 x 1050. If this resolution is not available the the graphics card cannot support this resolution and you need to set it as close to 1680 X 1050 as possible or upgrade to a better graphics card to get this resolution.
Try this...
1) On your Ipod Touch select "Settings."
2) Select "Mail, Contacts, Calendars."
3) Under Accounts select your "[email protected]" account.4) Under the "Outgoing Mail Server" heading select "SMTP."5) Under "Primary Server" it should indicate ""RR SMTP Sever" (or something to that effect) - If so, make sure that the "Server" is switched to the "On" position. (If it was originally switched off then switching it on should do the trick. - If not, continue to Step 6.6) On the "SMTP" page select "Add Server..."7) Fill out the fields accordingly. If you are unsure of the information check with you service provider (in this case Road Runner). - In most cases it would likely be "smtp.rr.com," plus you own "User Name" and "Password."8) Select "Save"
