What causes the residue?
Thanks for you question,
the residue that you are seeing is Calcium, it is a natural mineral that is found in all water, the easiest way to remove the calcium build up from your humidifier screen is to use (CLR) it is a calcium, lime and rust remover, a simple diluted mixture with water, then soak the screen for about half an hour, rinse the screen then reinstall, a soft water system would help with the calcium build up as well, but tend to be alittle on the spendy side, your could try inline mineral filters that need replacing yearly, I really hope that helped ansewr your question, let us know with some feed back, thanks again for your question, mr.grzz
I have a big experience to use the cool moisture humidifier, cause I am using this cool humidifier from previous 4 years. If you use a cool moisture humidifier so suggest you for use Honeywell HUL520W Mistmate Cool Mist Humidifier. It is very safe and healthy for your baby and home. Here have more details.
The Best performing Humidifier For Babies Kids 2018 Edition
We tested the water from the well and after leaving the water softener. This is limestone country, so calcium was what we expected. The results show the calcium content is high going into the softener and low coming out. The guy who installed the humidifier has never senn anything like our problem.
We did change from salt crystals to salt pellets in the water softener. Does anyone have experience with salt pellets in a water softener? Any problems?
https://besthumidifier2020.com/best-air-...
Try air purifier then.https://bestairpurifier2021.com/
