I'm not familiar with this brand of refrigerator but sounds as if you have a defrost system failure. most refrigs have a defrost timer that you can maually advance into defrost. if you can loate this on the unit then advance into defrost cycle if the heater comes on youll hear a sizzling noise from the ice melting on the heater. this means you have a bad timer. if the heater does not come on then you have a bad heater or defrost termination switch. I tried to find some service info for this mod but was unable to locate anything. good luck peyton
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would
normally give a pointer to articles I have already posted this response on, but
as this is such a potentially serious matter, I have posted my entire response
here for you.
According to
several sources I have checked, including most importantly, BEKO's own website,
the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges
affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops,
you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers
indicate the year of manufacture, so if your serial number doesn't start 00,
01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to
the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
The site also provides a mail address and a UK Freefone number that you can
call (Though I've tried the number and it keeps cutting me off!! I presume they
are swamped with calls)
Same problem here. I have changed PCB unit and potentiometer PCB but still -2 in fridge. Freezer is at -28. Thermistor reading is OK. Has any one wiring diagram for Beko CDA653fs/1 as I will put old stile thermostat.
