Ok so im trying to install this frakin hard drive's drivers so i can install windows 7 but i can find them nowhere
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
SOURCE: WDBAAF0010HBK-01 DRIVE ACCESS IS DENIED BY LAPTOP
you have to save the files using a computer with the same os that u origanlly and then format the drive on the windows seven computer then move the files back on to the drive
another thing to try is to try and update the drivers on your win. 7 computer
the last thing is you have lost all ur data and you should just reformat it
SOURCE: UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
SOURCE: I have the Thermaltake BlacX
I know it might sound a bit simple, but let's start at the beginning.
Make sure that the power is properly plugged in, and that it's securely plugged into the USB port.
Put in the hard drive you will be using.
Now turn on your device by clicking on the power button.
Listen out for a "ding" or a chime in your OS.
If you DO hear one, the hard drives may need to be properly formatted or not properly assigned.
If you hear a chime, go to your desktop and right-click on "Computer" and click "Manage"
Go to "Disk Management" and at the top, there are a few options, and check for your hard drives, and right-click on the proper one and click on "Change Drive Letter and Paths" assign it a letter, and check "Computer" to see if came up.
Thanks,
Please Rate.
SOURCE: Trying to install Hitachi Deskstar
Can you look in the bios and see if your motherboard is configured to use your SATA drives in AHCI mode or to emulate IDE mode?
Get online
and got to www.google.com In the google search box type: "Iomega
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Windows 7 drivers.
