Back razors
are specially designed large razors with wide blades that allow you to take the
hair off your back in a kind of scrubbing motion. It can be an effective way to
remove a lot of hair in a fairly painless method but it does increase the risk
of ingrown hairs and does not have long lasting results.
Shaving can
cause ingrowing hairs. This happens when the hair that is cut curls back and
grows inwards. It shows up as pimples or bumps and can look red and inflamed.
If it's a constant problem or gets infected, you may need to get advice from a
dermatologist.
The best way to shave your beard is close, but not too close. Excessive pulling and stretching of the skin causes the hair to protrude a bit farther out than normal. Shaving over stretched skin may cut the hairs below the surface of resting skin, thus increasing the risk of ingrown hairs.
The blades should be changed every 4-6 shaves or more
frequently if you have a very coarse beard. A dull blade will cause you to push
down harder in order to be effective, pulling at your hairs and skin and
causing irritation and possibly ingrown hairs.
The reason why you should shave with the hair growth is
because there is less of a chance of nicks and cuts, and because it reduces the
chance of ingrown hairs and razor bumps. Shaving with the hair growth tends to
be a little easier on your skin as well.
