Question about KitchenAid KCMS145J Microwave Oven
Kitchen aide microwave model kcms145jss-0
Microwave turns on but makes a different sound and it wont heat the food
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 338 Answers
SOURCE: KITCHEN AID KCMS145JSS 0 THE
bad control panel.. all power is routed through the control panel.. if your having a problem like that i would replace the control..
Posted on Jan 17, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
  • 15 Answers
SOURCE: lightbulb burned out for microwave model # KHMS
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Posted on Oct 13, 2009
  • 8909 Answers
SOURCE: I have a microwave model
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 30, 2010
I have a kitchen aid over the range microwave that makes a humming noise ehen off. Almost sounds like a buzzing transformer. ykhms1850ss-0 Is the model.
Possibly the wall receptacle has been wired with black and white wires reversed and/or the green ground wire not connected.
I had a GE microwave that periodically would buzz white operating but eventually the buzzing stopped.
Sep 16, 2016 | Microwave Ovens
My kitchen aid micro wave stopped heating the food. Everything seems to be working. Model Khms155L. I want to replace it but it is no longer in production. Is there a replacement model that is an exact...
Take your measurements and compare them to the measurements from various microwaves online, then go to the store that has the same measurements. I wouldn't use the microwave for fear of a fire.
Dec 25, 2014 | Microwave Ovens
I have a Kitchenaid microwave model KCMS145JSS-0. It is no longer heating. What can I do to repair it?
Check the door safety interlock safety switches for proper operation. You will find them inside the cabinet.
If they have failed, the oven thinks the door is open and therefore will not turn on the heat. This is the most common reason for failure.
May 30, 2011 | Microwave Ovens
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
My kitchen aid over the range microwave Model No; KHMS105EWH-0 stop heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 03, 2011 | KitchenAid Microwave Ovens
When I turn on the micowave; smell somthing burning
The magnetron (the part that heats the food) may be ready to burn out. If you smell the burning, you should then unplug the microwave, open it up and see if you can determine for sure that it is coming from that part. Unfortunately even if I am right, it is almost more cost effective to just replace the microwave rather than replace that part. You can run this microwave till it dies if you want, but I would be ready with a new one.
Let me know how this works out for you.
Benjamin
Apr 29, 2010 | KitchenAid KCMS145J Microwave Oven
Microwave makes a loud sound and then won't heat. About 3 years old.
It sounds like a failing magnetron. Sometimes they can be intermittent before they finally fail for good.
Chances are your oven has a 5-10 year warranty on the magnetron.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Dec 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
85 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
