Frigidaire front load washer LED display lost its mind!
I have an FTF2140E frigidaire front loading washer. Washes fine, but every few days, the LED panel starts beeping madly, lights all over the panel flash, we get something that looks like a "C" or "J" on the LED display.
There doesn't seem to be any obvious solution -- sometimes, cutting power for a bit helps, sometimes wildly spinning the knob, opening and closing the door, sometimes death threats...
Do we have a dead control panel?
Thanks for your help!
most front loader washers will wash fine all the time, however there is a pin switch on the front that the door strikes when closed make sure the door is closed and locked .
the flashing is an error code, count the number of blinks. also turn the power off. wake up the washer by touching any one bottom. then press cancel an pause buttoms at same time. it will display an error code. write that down an repost it
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
