Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Clean light on dishwasher won't stop flashing
I have a whirlpool dishwasher just over a year old and the clean light keeps flashing and I can't get the dishwasher to start, if I select the cancel button it runs for a couple of minutes but the clean light continues even with the door open or shut, all the buttons work if pushed but nothing happens.
  • 2 more comments
  • mamaof6 Dec 07, 2007
    I am having the same problem the dishwasher is not even a year old. The clean light keeps flashing and only when I hit the cancel button it keeps a noise and then shortly stops.
  • Anonymous Aug 27, 2008
    same problem here... it's happened a few times and I've had to have the repair man come in to fix it.
    Not impressed! Would not buy this product again.
  • Anonymous Sep 09, 2008
    We have the same problem light flashing
  • kk123456 Mar 16, 2009
    i have the same problem but after doing the reset code i tried to run a load and now my start light flashes and the dishwasher won't turn on
Yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
  • 6 more comments
  • glennpatters Apr 08, 2011
    you just save me and my wife a 129.00 service call. this is the strength of people like you and many others that help people at trying times.may God bless you!
  • scottandmica
    scottandmica May 11, 2012
    Thank you so much! Worked perfectly. I was just about to call the repair man and thought I'd look it up first. I would have never known! :)
  • C Carroll Jun 09, 2012
    Wow; just tried this and it totally worked. So grateful for you help! Thank you! My just over a year whirlpool stainless steel dishwasher clean light would not quit blinking and it would not start. I looked in the manual and it said to call the repair man. Also looked at e-how; said the same thing. I tried your directions and they WORK! Now why couldn't whirlpool put this in the manual? Just wondering...
  • astarks98375
    astarks98375 Jun 30, 2012
    thank you!!!!!!it work.....
  • cozad1954
    cozad1954 Jan 23, 2013
    Holy Cow ! ! Thanks to you my dishwasher is working again ! ! Bless You ! !
  • L Bult Jun 12, 2013
    You, my friend, are a God Send! Finally, clean dishes!! Thank you so much!!
  • missingan342
    missingan342 Jul 04, 2013
    thank you so much clean light no longer blinking,worked exactly as you said,btw my dishwasher whirlpool less than a year old.
  • Sharon MacPherson
    Sharon MacPherson Feb 26, 2014
    OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! BRILLIANT!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reset worked for me. I had the same problem as others. Thanks for your help.
Posted on Nov 10, 2008
  • 14 Answers
Flashing clean only means that the water didn't get hot enough at some point during the cycle. Are your dishes dry at the end? If not, it's the heater element, these will run you about $75.
If they are dry, then you're just not getting enough hot water into the washer. Make sure it's not connected to the cold water supply... (it happens)
You probably won't find that tech sheet. They stopped doing that years ago.
Posted on Dec 29, 2007
I had this same problem and had to have a tech out to look at it. It is a heater issue, but all he did was reset the dishwasher using the sequence mentioned above. What he told me was that the water temperature was not getting hot enough and suggested I run the hot water on my sink until its hot so the dishwasher immediately pulls senses water. The light came on the first time after about a year. It recently came on again and I reset the dishwasher again. Hopefully it won't happen for another year. BTW, I don't run the hot water at my sink and if I have to reset it once a year, so be it.
Posted on Sep 03, 2007
  • 5,911 Answers
The flashing clean light is usually an indication of a problem (error code). There should be a tech sheet inside the lower kick panel under the door. The tech sheet will give you details on what to do to clear the problem and/or troubleshooting advice. The flashing clean light may also be in conjunction with other indicators on the front panel. When reading through the troubleshooting section pay close attention to see if there are any other indicators lit at the same time. This will narrow down the error to a specific problem. I wish I could be or more help, but there are several different models that indicate errors in the same manner and mean different things. I hope this may be of some help to you.
Posted on Jul 02, 2007
    New Friend:
Thank to all of you! I did the sequence thing, and my washer is working!!! Yea!
Posted on Aug 20, 2010
Push the following buttons in this order within 6 seconds:heated dry, normal, heated dry, normal. This will restart the dishwasher but you need to check the heater in the bottom.
Posted on Sep 02, 2007
  • reneefwhillo Jun 03, 2012
    Thank you:) proud mom of 4 children
  • astarks98375
    thank you...i did what u said, heated dry, normal and i just keep pushing it back and forth and my dishwasher started......i was getting frustrated and annoyed but thank to u......
    New Friend:
I have this problem ,the normal light is flashing and dishwasher not working
Posted on Apr 02, 2011
  • 3 Answers
The reset codes work but you might need to power cycle the dish washer. If you don't have a switch for it be sure you know what braker it is on.
Posted on Apr 03, 2009
    New Friend:
I have the same issue except that every time I run a load after a reset it does the same thing.
Posted on Jan 16, 2013
Hitting HD/N/HD/N worked perfect, I did have to do it twice.
Posted on Jul 10, 2011
Start resume light continues to flash the dishwasher will will start on its on and run for a few seconds and then shut off light continues to flash
Posted on Sep 17, 2009
5 Suggested Answers
SOURCE:
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
SOURCE: Clean button will not go off
Alternate solution: Within 6 seconds, alternately press "heated dry" then "normal" buttons. Wait for all lights to come on and for the diswasher to finish washing the load.
Posted on Aug 19, 2010
SOURCE: Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Posted on Oct 20, 2007
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Dishwasher quits running and clean lite keeps flashing.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Dishwasher will not start.
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool dishwasher
I had the same problem with mine awhile back. I tried clearing it out like the book said and it would start blinking again when I started it. Then it wouldn't do anything. Based on research, I decided to replace the heating element and that solved the problem. Of course, now a year later, I am having other problems.
Aug 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool clean light flashes 7 times
Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
6,496 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
