Archos 605 WiFi Digital Media Player Logo
Posted on Jan 21, 2009
Just got Archos 5 goes into error 101...
My archos keeps on going into error 101 and it gives me the option to repair disk format disk or force touchscreen calibration I have downloaded the firmware update and put it into the root of the file. I have intalled it onto the archos multiple times and it just goes back into the code 101 screen after rebooting it.
  • Anonymous Feb 14, 2009
    hi there I have the same problem and the date today is the 14/2/2009 i hope you have a fix for this, if so can you post what you did to fix it,
    thanks inadvance,
  • Anonymous Apr 05, 2009
    I have the same problem. Tried to "Repair disk" but noting happens. Archos 5 60gb just reboots after 15-30 seconds. Then tries booting again and again and again.
    Have tried the reset button which makes no difference.
Anonymous
Level 1:
  • Contributor 5 Answers
  • Posted on Jul 24, 2009
Anonymous
Contributor
Level 1:
Answers
5
Questions
0
Helped
17519
Points
37
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Archos 101 internet tablet keeps going onto archos A101IT recovery when i turn it on i try to repair or format the devive and it just jeeps failing
every time i turn on my tablet it pop up archos A101IT Recovery.would u like to recover your system.no update firmwear.repair system.format system
10helpful
3answers
Recovery code 101
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
D) On the Archos 5 or 7
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
15helpful
6answers
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
C) Computer
3helpful
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Getting a white screen with 102 error message
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
2helpful
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
4helpful
2answers
Hdd_recovery 2
LAST HOPE !!!
ERROR CODE 102!!!
I JUST FOUND OUT THAT I HAD THAT SAME PROBLEM TOO...AND I WAS ABOUT TO THROW IT AWAY OR GIVE IT TO MY WILD CAT TO PLAY WITH !!! BUT!!! HERE IS WHAT I DID FOR MY LAST HOPE IN SOLVING THIS PROBLEM...
FIRST HERE ARE THE DETAILED PROBLEMS I HAD...
*NO RECOGNITION OF MY ARCHOS IN MY PC...
*ERROR SCREEN..."SYSTEM DAMAGE...REPAIR? NO,REPAIR,FORMAT DISK"
*SELECTED ANY OF THE OPTIONS...SAME STUFF...BACK TO THE SCREEN...NEVER ENDING STORY...
OK...THIS IS WHAT I DID...
1 DOWNLOAD THE LATEST FIRM FROM WWW.ARCHOS.COM...TO YOUR PC !!
2.AFTER DOWNLOADING THE LATEST FIRM UPDATE TO YOUR PC... PLUG IN YOUR ARCHOS TO YOUR COMPUTER...
3 YOU WILL NOTICE THE ARCHOS IS NOT DETECTED AND YOU ARE IN YOUR SCREEN ERROR STILL...OK...TURN YOUR ARCHOS OFF BY CLICKING ON THE POWER BUTTON FOR ABOUT 5 SECONDS OR UNTIL IT TURNS OFF...(NOTHING ON THE SCREEN BUT BLACK...)
4. THEN...WE ARE ABOUT TO TURN IT ON AGAIN...BUT BEFORE THAT... LEAVE ONE FINGER ON YOUR TV/LCD BUTTON PRESSED !!! HERE IS THE SECRET...THEN TURN IT ON !! BUT...DO NOT LET THE TV/LCD BUTTON RELEASED !! IS LIKE YOUR ARE GOING TO PRESS BOTH OF THEM AT THE SAME TIME...AND WAIT FOR FURTHER INSTRUCTIONS...
5. THEN ANOTHER SCREEN WILL APPEAR..SORT OF LIKE...HDD RECOVERY 2...YOU MIGHT WANT TO UNFORTUNATELY FORMAT YOUR DISK...
6. ONCE IT TELLS YOU DONE ! DO NOT PRESS ANY BUTTON... THE PC WOULD NOW RECOGNIZE YOUR ARCHOS...AS A HARD DRIVE..ETC...
7. ONCE IS DETECTED BY YOUR PC...REMEMBER THE FILE YOU DOWNLOAD IT... DRAG IT DOWN TO YOUR ARCHOS..IN THE ROOT SECTION... THAT MEANS...IN NO FOLDERS INSIDE THE ARCHOS...BUT BY ITSELF...JUST LIKE ANY OTHER FILE IN A FLASHDRIVE IF YOU MAY...
8. THEN IT MIGHT ASK YOU AGAIN YOUR PC...YOU WANT TO FORMAT THIS DRIVE...JUST SAY YES....OK...WHATEVER... AND LET IT FORMAT...
9. FINALLY AFTER THE FORMAT SITUATION HAPPENS...YOUR ARCHOS WILL ACCEPT THE FILE...AND IT WILL BE DOWNLOADED AUTOMITICALLY...THEN REOPEN IT TO MAKE SURE IS THERE ALREADY...
10. FOR THE LAST STEP... ENJOY ! MY ARCHOS IS BACK TO NORMAL..IT REBOOT AND EVERYTHING IS FACTORY MADE...HOPE THIS WORK GUYS...AS FOR ME IT DID...
PS. PLEASE BE PATIENT ON THAT OPTION OF THE TV/LCD FOR IT MIGHT NOT WORK RIGHT AWAY...I TRY IT LIKE TWO TIMES BEFORE IT LET ME FORMAT EVERYTHING...BECAUSE YOU MIGHT GET ERROR MESSAGES LIKE..."MEDIA FAILED" ETC... JUST KEEP ON TRYING UNTIL IT ACCEPTS IT.. LET ME KNOW WHAT HAPPENED...
2helpful
Same problem
LAST HOPE !!!
ERROR CODE 102!!!
3helpful
3answers
Archos 404
Choos 'Repair disk' while connected to your computer, then go onto www.archos.com go into support, downloads, choose your model and clck on download archos..... Then go into my computer click on the archos device after that has finished downloading and drag that file into the archos folder and the rest it does itself.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
