Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute or two then shut down. I read that a high current draw from the lamp can cause the set to turn off, I do not know if this will work because of the protection circuit but was thinking if the lamp was removed will the set turn on? If so you would still hear the audio and if it did not shut down that would indicate that there was a good chance replacing the lamp would solve the problem. Does anyone know if the set will be damaged by running it without the lamp or for that matter will it even turn on? I have the same problem! Did you replace your lamp and does it work now?
  • hizmelody Jan 21, 2009
    Ok- I've paid more attention to timing and the TV will stay on 1-2 minutes and then shut off for about 30 seconds while the standby indicator blinks continuously (55 times) and then the tv turns back on. I appreciate all of your help, but could you make it a little simpler to understand?
    Also- my exact TV model is
    Sony Wega SXRD # KDS-R60BR1
Anonymous
Level 3:
Genius:
  • Master 1,550 Answers
  • Posted on Jan 21, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1550
Questions
Helped
451049
Points
4209
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
  • Anonymous Jan 21, 2009
    The AKB circuit is not
    satisfied with the CRTs cathode current and keeps the CRT blanked. The warmer it
    gets, the more likely the circuit is to allow the picture to come on.
    AlSo you need to check the Capacitor On PS unit, because the capacitor can dry (
    electrolit liquid ) you can try to replace all capacitor High voltage
    On ps unit you TV
    You can do it with the help of service manual . Else you need to call technican to check the circuit .
Anonymous
Level 2:
  • Expert 59 Answers
Anonymous
Expert
Level 2:
Answers
59
Questions
Helped
24112
Points
158
High amp draw by a lamp is usualy a sign it has whent bad
also don't bother taking the lamp out because the lamp light should blink insted of the set coming on.
Hl72a650
color wheel issues replace light engine
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
2helpful
2answers
Stalling coming on
LG's are known for having bad capacitors in the power supply. These components will cause all kinds of problems like not turning on, no backlight or no video and are known to do this after the TV has been off for a few hours or days. You will need service on this TV.
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
1helpful
4answers
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
2answers
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
1helpful
4answers
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
[email protected].
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
