While trying to program my remote to operate my cable box (scientific atlantic) I hit sat/cbl and instantly the tv channel is changed to channel 17. I now have operational control of my cable box but can't watch anything because my tv needs to be on channel 3. I can change the channel back to 3 with my tv remote and everything works normal. Course doesn't make much sense to have an all-in-one remote if I have to do this. Is there a way that you can change the sat/cbl button to default to channel 3 when pressed?
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
code
OK.
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
Aim the remote control at the device and press POWER
CBL/SAT,or TV).
then release SET.
Use the Manufacturer's Codes to
5. Aim the remote control at the device and press POWER
6. Repeat steps 1 through 5 for each device you want to control.
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
5. Aimthe remote control at the device and press POWER
code in the following boxes:
OK.
I am having the same problem except that my TV changes to channel 2. Customer service(at audiovox, explained below) told me they don't know why it is doing this other than there is a compatibility issue between the remote and my devices. This was after I had to look up the RCA customer support number online and was then given another phone number by RCA and told to call the manufacturer of the remote, Audiovox. The RCA customer service rep was very rude when I asked if she could repeat the number of Audiovox. After talking to several customer service representatives at Audiovox and trying their solution of resetting the remote several times, I was finally given the following solution:
1.Turn on the TV
2.Set the volume that I intend to listen to the TV for the entire time I am watching TV
3.Cover the infared reciever on the TV (hence setting the volume becuase with this covered volume is unadjustable)
4.Press the satallite device button and begin watching.
This is just rediculous. Even if I am doing something wrong in setting up this remote, after following all given directions exactly, and the difficulty I am having is my own fault, I expect customer service to be courtious and knowledgable enough to walk me through it. If the problem lies with the product, I expect them to be honest enough to tell me that this product will not work with my devices instead of giving me this circutous solution. I'm returning this remote to the store and never buying anything RCA ever again.
remote won't work on conventer box
