Question about Hotpoint Ultima WF865 Front Load Washer
How to take the top off a wahing machine - Hotpoint Ultima WF865 Front Load Washer
    New Friend:
At rear of machine at the top, on both sides are small screws or bolts. Remove these and the top of the machine should slide back and remove.
Posted on Jan 09, 2013
SOURCE:
Wahing machine makes a loud banging noise
This could be due to pending failure of the flexible joint beneath the tub
Jan 22, 2013 | Kenmore Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
Is it possible to repair a wahing machine lid switch? 110.24712300
The top of the machine usually can be lifted by puling up with the front edge of the opening-Hinged at back-usually remove two switch mounting screws and replace switch and reverse procedure to close lid.
Aug 24, 2010 | Whirlpool Washing Machines
Leak in the front of wahing machine one of the hose how do we get to the hose
At the top of the machine where the controls are at look for 2 screws (Usually philips) either in the front of back of the top base.
Unscrew those and then the top piece can be removed easily.
Once removed pop the two metal brackets out with a flat screwdriver, and unplug the lid switch.
At this point you should be able to remove the entire top to have access to the inside.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
Kitchenaid top load wahing machine # YKAWE870BW1
You need to replace little gears called agitator dogs. Once agitator is removed pull top half of it off. Exposes the dog carrier.
Nov 28, 2007 | Whirlpool LSB6200KQ Top Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
