Korg ESX1 Electribe SX production station (with ) Logo
Anonymous Posted on Jan 09, 2013
Cannot format SmartMedia card on the KORG ESX-1
My KORG Electribe ESX-1 all of a sudden stopped working (although the knobs and functions seemed to be working fine). I thought that restoring the factory settings would do the trick. Since finding SmartMedia cards are hard to find in my neck of woods (Brazil) I found a XD/ SmartMedia adapter and tried to format it on the ESX-1 before reloading the factory settings. Much to my dismay, it kept showing the message FORMAT ERROR. Already tried to reste the system but no good. I'd appreciate any help in that matter. Cheers
5 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Jan 09, 2010
SOURCE: I'm looking to get the pre-set patterns to play on my Korg DDD-5
A demo on YouTube shows the owner pressing one of the buttons on the left side to select possibly a bank as well as the start.. I could NOT find a manual online to download.
Anonymous
  • Posted on Jan 17, 2010
SOURCE: os system not loaded! hard drive was totally formated. PA800
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
Fred Yearian
  • 5603 Answers
  • Posted on Jun 18, 2011
SOURCE: I have a old (but almost unused) Korg d1200
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Fred Yearian
  • 5603 Answers
  • Posted on Jul 30, 2011
SOURCE: The pitch bend of my
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
Anonymous
  • Posted on Aug 01, 2011
SOURCE: Hello my name is Ludwing Sanabria, I live in
Hola mi nombre es C?sar , tengo un Korg PA 50.Desde hace un tiempo, al tocar en vivo algunos sonidos de registros empezaron a distorsionarse.En algunas ocasiones el vol?men sub?a y bajaba.Lo he llevado a un t?cnico y como primera soluci?n me *** una fuente nueva, estimo yo que supuso que era una cuesti?n de tensi?n.Pero el problema es aun peor, ayer encendi el teclado y no emite sonido alguno!!!, ni con sus parlantes , ni conectado a un equipo!!!.Como si estuviera MUTE el volumen.Ayuda por favor
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
I connected it to 220v, but the power supply is the US one (120V). Is there a chance that my ESX still works?
• Power Supply should be checked first by a multimeter
then the ESX will follow.
other option:
• Borrow a working power supply adaptor one from a friend,
just to determine if it is the ESX , the power supply or
both ( I just hope not )
Once determined , you can either repair or replace
the AC/AC power supply
Let us know how it goes
1helpful
How can i get hold of a korg electribe emx sd users manual?
Go to the court website, select your product, and download the drivers.
5helpful
2answers
Hello there how can i reset my korg kaossilator pro please help i cant get it back to factory settings
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
I need to downlaod an ownwers manual for a Korg rmk2 electribe
Try this:http://www.korg.com/Support.aspx Hope this helps.
Mar 19, 2010 • Music
KORG EA-1 MK 11 ELECTRIBE OWNERS MANUAL
Thanks For Using Fixya A Direct Download Is Here.
Enjoy And Thanks Again.
Sincerely,
Michael Scott
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
