I have a dryer that has power (i checked power cord and it's plugged all the way in) that won't start any cycle. the lights come up showing power, but it makes some sound like it wants to start but won't spin at all.
SOURCE: I have a Frigidaire Affinity
Sounds like you hooked the cord up wrong... tripped the breaker...fix the cord and reset the breaker...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Thanks for the feedback. Where do you access this fuse from, and where can I buy a Thermal Fuse to replace the bad one? I am assuming that is on the backside of the dryer somewhere, correct? Please advise. I appreciate the help.
