GENERATOR WON'T START. IT HAS NOT BEEN STARTED IN ABOUT THREE YEARS.IT DID START AFTER I REPLACED SPARK PLUG,BUT ONLY FOR ABOUT 30 SECONDS..ALSO SPRAYED STARTING FUID IN CARBERATOR. NO GO.
FIND THE FUEL SHUT OFF VALVE.IF IT WAS CLOSED WHEN YOU HAD IT RUNNING,THE FIX IS AS SIMPLE AS DRAIN OLD FUEL,REPLACE WITH FRESH GASOLINE,OPEN THE VALVE TRY TO CRANK IT AGAIN.
IF IT WAS OPEN WHEN IT WAS RUNNING,SOUR GASOLINE AND VARNISH HAS LIKLEY GOT TO THE CARBORATOR.
REMOVE THE AIR FILTER,LOCATE THE BOLT IN THE CENTER,ON THE BOTTOM OF THE CARBORATOR BOWL AND REMOVE IT. CAREFULLY EASE THE BOWL STRAIT DOWN,AS NOT TO BEND THE TAB THAT CONTROLS THE FLOAT LEVEL,OR LOSE THE FUEL INLET JET. EXAMIN THE BOWL FOR CORROSION OR GUNK.
THIS IS AN INDICATION THE CARBORATOR MAY BE PLUGED WITH GUNK,WHICH COMES FROM GASOLINE SOURING AND TURNING TO VARNISH AS IT EVAPORATES OVER TIME.
ON THE CARBORATOR,WHERE THE BOWL WAS TAKEN OFF,IN THE CENTER ON THE BOTTOM NOTICE THE FUEL PICK UP TUBE,TAKE A PIPE CLEANER AND CLEAN IT BY PUSHING STRAIT UP AND DOWN A FEW TIMES,THEN FLUSH IT WITH CARB CLEANER.
REPEAT THIS UNTIL IT IS CLEAR.
LOOK CLOSELY AT THE SIDE OF THE PICK UP TUBE FOR A VERY SMALL HOLE,WITH A SMALL WIRE,CLEAR THE HOLE AND FLUSH WITH CARB CLEANER.
CAREFULLY REPLACE THE BOWL AS NOT TO BEND THE TAB ON THE FLOAT,MAKE SURE THE NEEDLE JET IS IN THE NEEDLE SEAT AS YOU PUSH THE BOWL INTO PLACE.
PUT THE BOWL BOLT BACK IN,CAREFUL NOT TO OVER TIGHTEN IT.
WITH FRESH GASOLINE IN THE TANK,AND THE FUEL VALVE OPEN,YOU ARE READY TO TRY CRANKING IT.
IT MAY TAKE A FEW TRYS.
IF YOU FEEL CLEANING THE FUEL SYSTEM IS TOO MUCH FOR YOU,PLEASE DO NOT ATTEMPT THIS.TAKE THE MACHINE TO A SMALL ENGINE MECHANIC.
YOU MAY CAUSE COSTLY DAMAGE TO DELICATE PARTS OR UNINTENTIONALLY CHANGE THE FLOAT LEVEL CAUSING FLOODING OR STARVING OF FUEL TO THE ENGINE.
BEST OF LUCK...
