I have followed the manual for turning off message function. We have this service through our telephone company.This is what I have tried. Open menu and select global setup, select VMWI, reset, than select YES. this still does not stop flashing red light. What do I do to stop this???
SOURCE: GE 28128
Call your phone from another number and leave a message. Then, check your voice mail, delete the message, and hang the phone up. That should cause the blinking to stop. It worked for me!
SOURCE: tmc4000 voicemail light no longer flashing when messages are waiting
First of all here is a link to the manual for you ...enjoy !
http://www.sellcom.com/ET4000%20users%20guide%20%20v7%20090803.pdf
On page 72 there are instructions for re-setting all programmed features to default, then you can start afresh...good luck
SOURCE: ge model 28112 dect 6.0
If you restore Factory Defaults under "Mute" menu it will stop blinking.
SOURCE: flashing message indicator light is on but there is no message
from operators dss hit mw key then the ext you are trying to clear
SOURCE: message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
This should resolve the blinking light.
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
