Model 04510-249
SOURCE: I lost my instrction manual!
Step 1: Detach the front panel from the 2 front post using an allen wrench
Step 2: If the mattress support is not in the lowest position unscrew the bolts and move it to the lowest position
Step 3: Using the allen wrench, attach the guard rail using 4 bolts between the lest and right front post (the guard rail would be that extra piece that you couldn't do anything with while the bed was converted to a crib. Looks kinda like a wooden board)
Step 4: Tighten all screws and put the crib mattress back in
SOURCE: I need replacement parts for my crib.
any hardware store will have the parts you need; just take a sample bolt and, nut to them and, they will find them for you. these are not a special part exclusive only to your crib.
Testimonial: "Thank you. I did as you suggested and now have the parts I needed. My crib is now assembled."
contact the manufacturer direct as they are the only people who can issue a certificate for the crib
they will also have a manual for it as it will be a requirement under safety law
