Question about Fedders A7DH45B2A Dehumidifier
Need wireing diagram
Fedders window unit Mod: 15cm44h-a, S/N: 18l936828
No Heat. Thermostat is closeing, Switch closes but shows 45 ohms resistance, Should be 0. Not sure if switch is bad. need wireing diagram to properly troubleshoot. Electrical element is good.
Help please
  • 195 Answers
SOURCE:
Model# a6dh50b2a. Bucket empty. Why does full bucket indicator light up and unit turns on and right off?
This can be a fault of the internal interlock (switch) that is closed when the bucket is in place. Normally, the purpose of the interlock is to prevent the dehumidifier from mindlessly dumping condensate into a missing bucket.
Sep 21, 2015 | Fedders Dehumidifiers
HD456E dehumidifier shows it is on but nothing happens - no compressor running. The humidity is 75% in basement and have it set to run at 45%. Any possible fix or is it time to replace eventhough it is...
You can normally hear a humidistat open and close if you listen closely. Also, the water tank has either a float or pressure switch that will shut it down.
Jul 30, 2013 | Haier HD656E Dehumidifier
Why does my dehumidifier run al the time ,i have the humidity set at 45 and when the room temperaturegoes down to 55 it keeps running.
The 45% setting is too low and the setting is never satisfied, so the unit keeps running to try and reach 45%. Try setting to 50 or 55, this is a very comfortable range. I was not clear on the room temperature being at 55 degrees. Is this what your thermostat is set to or is this the actual room temperature. Brrrrrrrrrrrr
Sep 01, 2011 | Fedders A7DH45B2A Dehumidifier
Haier dehumifier shows bucket full light. There is no water in the bucket. The float switch has been held closed and electrically shorted, neither action causes the light to go out. There appears to be a...
Since I answered your similar question earlier and now have more details on what happened. Shorting out the bucket full switch, more than likely caused more electronic problems in the control board.
However, there is one thing you can try. Turn the Master ON/Off Switch to OFF. Unplug the unit for 15 minutes. After the time has elapsed, plug the unit back in, turn the Master ON/OFF Switch to ON and hopefully, the electronics will have reset themselves during that time out. Before doing any of this, make sure the bucket' float valve is in the DOWN position.
If the above doesn't solve the problem and you decide you want to replace the control panel electronics go the link below, to find the closest Haier Parts Dealer to you.
http://www.partlinx.com/haier.asp
Jun 13, 2011 | Haier 45-Pint Dehumidifier
The bucket full shutoff does not clear after it is emptied. The switch seems free to move and so does the float level arm. This is a 54501 dehumidifier.
If you have access to an ohm meter, I would UNPLUG the unit and then see if the switch is opening and closing. By the way, most of the switches have a clicking sound when then open and close.
Jun 04, 2011 | Kenmore 54501 Dehumidifier
Lites up but does not run
First check the water collection bucket, to make sure it's properly seated and making contact with the safety switch. Also check the humidity level you have the unit set on. It may be to high for the humidity level in your house. Reset the humidity level to either minimum or if you have an LED screen 45%. Remember, the lower the setting, the more humidity will be removed.
To do an in home test of the unit, move it to a bathroom. Turn the unit ON and set the humidity level to it's lowest level. Turn the shower ON hot enough to generate steam. Do not turn the bathroom's exhaust fan on. As you exit the bathroom, close the door. Wait 15 to 20 minutes and turn the shower OFF. Allow the dehumidifier to run for several more minutes, before checking the water collection bucket for water. If you find any water in the bucket, it's working as it should. If not, it's time to replace the unit. Under most circumstances, I would suggest possibly repairing it. But, Fedders is out of business and replacement/repair parts are a scarce as hen's teeth.
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
May 24, 2011 | Fedders A7DH65B2A Dehumidifier
Collects very little water never fills up the container. all fiters are clean
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 11, 2010 | Fedders A7DH45B2A Dehumidifier
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
302 people viewed this question
Top Fedders Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
jasbo
jasbo
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
