HELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok//
yes, this watch uses battery, you had to replace it with a new one. you had to bring it to watch service center because they have what you need for your watch. i hope I solved your problem.
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
If you go to the Festina web site (www.festinausa.com), you will see a contact address and phone number where you can contact them to set some instructions.
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
