2003 Pontiac Vibe Logo
Posted on Jan 08, 2013
2003 Pontiac Vibe - 4 Cyl. 150k miles. Ignition coils keep going bad - every 4-6k miles. Coil 1 has been replaced 4 times, Coil 3 once. Coil 4 twice in the past year (20k miles). All spark plugs
Car is driven a lot in city. around 1500 miles a month. Coil 1 has been the biggest problem. Engine runs a bit rough on and off for a few days - then it's really rough and CEL comes on. p0301 (or whatever cylinder it is) We've also had a p0171 (fuel mix too lean) come up a few times in a year or so. I've replaced the air filter, put fuel injector in, and I've poked around for obvious hose leaks (haven't found any) - I'm not sure if this code is related to the coil problems - the errors don't come up together.
  • Anonymous Jan 08, 2013
    Put in clean oil Full Syn like Mobil 1 form Wal Mart 5W-20 or 5W-30
A
Anonymous
Install new spark plugs, 4 new coils & replace the oxygen sensors
O2 Sensors are only good for 100,000 miles, then slow
down or quite
No idea why the coils do not last 5 or 6 years
Cylinder #1 is always at the front on a 4 cyl
Go to Rock Auto --Buy Wells Coils,NGK Double
Platinum Plugs & NTK O2 Sensor
Those parts are expensive because you have a Totota
Motor I guess
Clean MAF Sensor with CRC MAF Sensor Cleaner
5 Related Answers
Anonymous
  • Posted on Jan 01, 2011
SOURCE: 2009 Vibe - Traction control & engine lights on, VSC off flashing
The exact same thing has just happened to my 2009 Vibe. It has 44,000 kms on it. We'll be getting it looked at in a few days. Did you ever get this resolved?
Anonymous
  • Posted on Sep 02, 2009
SOURCE: 1997 PONTIAC SUNFIRE ENGINE CODE 0P300 . NEW CRANK
none fire on plug and the coil and the mdule ers good
Chuck
  • 85 Answers
  • Posted on Feb 21, 2009
SOURCE: No fire from coil to #1 cylinder
Ok since you did all that if you want to swap around fuel injectors taking note where you put cylinder 1 injector. Lets say you swapped it with cylinder 4 . Now if you get a different code say P0304 which is for cylinder 4 misfire then you know it is your injector at fault. These are wear items and should be replaced every 100,000 miles.
Also i would suggest if you dont want to do that is get some good high octane gas when you are completely empty and fill to 1/4 tank now put in Lucas Oil fuel injector cleaner and run the car till empty. Now fill up tank with high octane gas in see if this helps. Clear code after your second tank of gas and see if the code comes back. if code does pop back up then i would do the swapping of injectors as i stated earlier. I hope this helps and good luck with the diagnosis.
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Oct 24, 2009
SOURCE: Engine code states cylinder 2 misfire. Replaced
sounds like a bad injector, just connection at the injector, also check for leaks at intake, one more thing , do a compression test on that cylinder start there, good luck.
Anonymous
  • 1244 Answers
  • Posted on Jan 19, 2010
SOURCE: 04 Pontiac Vibe bad gas mileage without a code and then the p0420
that code is from having the plugs wires reversed as you did and the o2 senors regrsitered the overload on gas emmions once you remove the battery cables for about 5 minutes and then recconect and run the engine it should be okay
1helpful
2answers
2005 Pontiac vibe fuse for coil . were is it located at
no fuse for coil if no power to coil[s] assuming its the ignition coils sheck and test wiring and coil for damage or failure
Both coils do not fire on 1 and 4. Will start but only running on 2 cylinders. Could both coils be bad or should I look elsewhere?
Part 3 -How to Test the Ignition Module and Crank Sensor ...
easyautodiagnostics.com > Ford > 2.3L
Mar 1, 2012 - Spark plugs for cylinders #2 and #3 get spark at the exact same time. ...voltage -12 Volts) to both individual ignition coils within the coil pack. ... Ford Mustang or Ranger (or 2.3L Mazda B2300), this is what you'll need ... for this 'Switching Signal' at the coil pack... but you can also test this ... 1991, 1992, 1993.
How to Diagnose a Misfiring Cylinder (2.3L Ford Ranger ...
troubleshootmyvehicle.com > Ford > 2.3L
Apr 3, 2012 - Bad Fuel Injectors can cause a Misfire Condition. ... the ignition system on the 2.3L Ford Mustang or Ranger consists of 2 ignition coil packs, ...
2002 ranger misfire rough idle - Discussion on Topix
www.topix.com > Ford Ranger
Jul 27, 2007 - My truck is giving the code misfire in number 4 cyl. I replaced my spark plugs, Wires, Coil packs (both of them) and all my fuil ... three (3.0L v6) go bad, the fuel/air mixture gets messed up. Judged: 2. 2 ... My truck runs rough only at idle. ...code for ford ranger 2002, 2.3 5speed. truck runs like a champ but that ...
Extremely stumped! I need the best and brightest 1994 Ford ...
answers.edmunds.com > Edmunds Answers
Misfire on Cylinder 3 swapped plugs between 3 and 4 on Pontiak Aztek 2003. Misfire remained on cylinder 3. Swapped ignition coil 3 and 6 with ignition coil 1 and 4 misfire still on cylinder 3
Try a new plug wire on cyl 3 if that doesn't fix it you could have a bad valve or compression problem on cyl 3 Try doing a compression test also If it has injectors for each cylinder you could have a bad injector for cylinder number 3
2helpful
Hyundai 2.7 P303, P306 at the same time
I would say its the coil. A crank or cam sensor could cause one cylinder to miss, or go completely dead, but I doubt it would affect two cylinders. And you would get a code for either sensor.
What are cord packs, and culd this be a problem why my 98 Pontiac grand prix wont start
coils packs are a set of 2plugs that are fired by one coil.so if you have a 6 cyl you will have 3 coil packs.its unusuall that all coil packs go bad at once.your no start could be caused by an ignition module,crank sensor,computer,bad connections,bad wiring,even a fuel problem.there may be a code set in the computer that may help to find were ot start to diagnois.it will have to be checked out to pin point the area.
2helpful
2answers
I have a 2000 expedition with a misfire prob. had it checked with a scanner and it said #3 cyl was misfiring. i changed coil pack once and it was good for about ten min and started again. i changed it a...
All you need to do, is buy one new coil,
one time at auto parts store $60.00 once
One bolt,you can install the COP Coil in
less then 30 min
You disregard the PO303 Code and walk
the new coil until you find the bad one.
You can do one or two cylinders a day,driving
at least 25 miles and getting it hot in between
Codes don't always match up to the problem cyl
When it isn't corrected put the old coil back where
it was, move the new one to the next cyl
1helpful
2answers
2000 ford mustang code 453 and missfire cyl 5 where is the cyl
a haynes manual from a parts place will show you--or chec the condition of each plug wire-if one looks bad or falls apart--probly need to get all new wires /plugs
Reoccuring Dead Spark Plug Coil on 2003 vibe
Check you spark plug and engine ground. if one of those is causing too much resistance then it can overload the coil.
I saw that one, on one of my cars and it was the spark plug that was loose but the car was not missing fire, it was just having too much resistance and overloading the coil.
Dead cylinders 2003 sebring
it sounds like you may have the wires on the wrong coil. It should be #1 on the #4 coil, and the #3 wire on the #2 coil. you probably have them backwards so 1 and 3 are firing on the exhaust stroke.
the firing order is 1-3-4-2.
they should be hooked like this.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
