Older JBL Sub connected to my Arx-V673. When I power down the receiver, the sub does not power down.
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
SOURCE: yamaha rx-v2500 receiver how to hook up speakers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag. press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
SOURCE: i just bought a yamaha
sell the bose sub, buy a nicer yamaha sub, enjoy the 200 bucks you have even after you buy a new speaker.
