I bought a shaver In the US, lost the cord, then moved to Peru. I believe the shaver is 12VDC, so I guess the cable has an adaptor. I hope it is a 100-220 VAC adaptor. Help!
1. Read the voltage info. on the razor. Their should be a label on the razor or info. in the instruction manual that came with the razor. 2. If the label doesn't say 120/220 input voltage you will not be able to use your razor. 3. If you use a adapter but the razor is rated for only 120volts input & you plug it into a 220volt socket you may burn your razor up & it may even cause death. 4. Remember find out the input voltage on the razor label & make sure it's the same as the output voltage as your wall socket. If it doesn't match, don't plug it up!
SOURCE: Braun 4775 Electric Shaver Power cord
I would visit this website: http://www.braun.com/na.html
They have a link for replacement parts and a Contact Us link. By contacting Braun, you may get the name/address of the nearest parts dealer. I would think Los Angeles has a bunch
of repair shops and parts dealers.
SOURCE: shaver has lost charge, won't recharge on station,
here is the link to the manual and the service center http://www.braun.com/us/home.html
SOURCE: I lost my Philips Coolskin 7775X shaver charger.
Hi, You can purchase a new charging cord from electricshaver.com for around $23.00 which is probably the best thing to do if you want to keep using the shaver.
Otherwise the specs for the shaver are as follows:
The part number for the replacement charging adpater cord is #3605160
Here's a link to the part you're looking for, should you decide to purchase a replacement instead of trying to make your own charger, which will be difficult unless you have the full array of electrical components and ability to fabricate it.
http://www.electricshaverstore.com/get_list_144.htm
You can also give them a call at 1-888-476-1785
Hope you find this Very Helpful and best regards!
SOURCE: lost head for PHILLIPS HS8460 shaver
You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hs85-replacement-heads-p-253.html
SOURCE: I plugged the shaver in Italy, I believe I fried
Yes. take both the shaver and cord into any radio shack store where they will test it for you and/or sell you the device to test it yourself. Joe
