Cisco ASA 5500 Firewall Logo
Posted on Jan 20, 2009
Sir, I have an ASA 5500 series device and i want to configure it user licence but i dont know how to configure it plz give me a proper solution
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
15919
Points
32
Use a web browser and point it to the private IP address of the ASA. Download ASDM and run through the wizards.
Good Luck!
How do I backup the firewall configuration - Cisco ASA 5500?
Easiest way to is so issue the following command on the cli:
more system:/run
This will get any preshared keys you have in the config.
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
1helpful
Cisco ASA 5505 Firmware
Yes, it is possible and Yes you have to purchase it from Cisco.
Sorry, that is how they make the big bucks.
Consider a service contract on the unit, then you can download the firmware much cheaper.
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
I need a L2TP configuration for my PIX 515 and ASA 5505
You can do this, For your ref i hv given you a link
http://channel9.msdn.com/forums/9GuyAroundTheWorld/251722-Cisco-Pix-to-Windows-Vista-Native-Client-Using-L2TP-IPSec/
38helpful
18answers
I WANT NOKIA3230 ULTRA MP3 LICENSE KEY
Your Ultra Mp3 Player
License Key : 27581
Feb 15, 2009 • Nokia 3230
Asa 5505 firewall problem
PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/pppoe.html
1helpful
2answers
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
