New tv has four hdmi outputs and one component output. Using Direct TV. Having problems getting connectivity. Currently going from direct tv to television set using hdmi, but can't get audio from Direct tv to marrantz sr8200..
SOURCE: No sound from TV
check the fuse output line in the speaker! or maybe you are in protect mode! checkout the speaker, maybe you have defective speaker, thats why your unit in protect mode, thats why no sounds coming out!
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
SOURCE: I can only get audio, but no visual, when
I think you may have the wrong idea about this unit. It only receives sound. It isn't a television tuner.
SOURCE: Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
SOURCE: component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
