For most front-loaders: Plug off the wall mains. Remove the plastic clamp holding the
seal to cabinet & peel off the cabinet. Push downwards on the seal
close to the tub & the seal will come off - it's just held by a
spring on the periphery.
Lubricate the slot which fits over the tub with washing-up fluid.
Starting at the top, press the seal so the flange of the tub enters the
slot on the seal. Work your way round the using thumbs to force the slot
on the tub flange. When slot is on the flange all way round, fit the
spring which holds it on. The spring goes into a slot on the outside of
the seal. This is quite difficult and you may need another pair of
hands.Fit the outside of the seal to the cabinet - this
is easy and fit the plastic clamping ring. Test for leaks before
using. Use rinse to test as the water level is higher. (There
is no glue anywhere, only clamps,etc)
Could be a weak door spring, or worn or cracked catch, meaning that it is not latching in properly, try activating the door lock with a screwdriver or similar if you can, if still no joy, then could be a board or cumminication prob between boards
please rate my solution.
Thanks.
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
switch off from mains
remove outer clamp holding door boot to cabinet and peel off door boot.
remove work top
there is a clamp holding door boot to tub. undo clamp and pull door boot away
lubricate slot in door boot that goes on to the lip of the tub using washing up fluid
starting at the top, insert lip of tub into slot in door boot. working both ways round, push door boot onto lip
fit outer clamp
push door boot on to lip of the cabinet and fit clamp.
test for leaks on a rinse cycle (water level is higher) water will be a bit foamy till washing up fluid is washed away
easy job but needs a bit of patience so go for it
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
i will tell u step by step
1)open the door undo the clamp that holds the front of the seal on it is around the lip push door seal back so its out of your way into the drum
2)take the lid of look to the front were your seal is fastened onto the outer drum this is held into place with a screw clamp unscrew it and u should be able to ease the door seal of from around the drum reverse these actions to replace the new 1 i have sent these instructions too 3 other people they have found these instructions easy to follow and do
