Pine Technology XFX GeForce 8400 GS / 256MB DDR2 / Supporting 512MB with TurboCache / PCI Express / DVI / VGA / HDTV Graphic Card Logo
Posted on Jan 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY COMPUETR CANNOT GIVE A CLEAR DISPALY - Pine Technology XFX GeForce 8400 GS / 256MB DDR2 / Supporting 512MB with TurboCache / PCI Express / DVI / VGA / HDTV Graphic Card
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Mar 02, 2009
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591520
Points
4916
DO YOU HAVE THE CORRECT DRIVERS
IS THERE ANY OTHER DEVICE CONFLICKING WITH THE OPERATION OF THE VIDEO SIGNAL.
YOU COULD TRY IN THE SAFE MODE
GO TO CONTROL PANEL, OPEN DEVICE MANAGER, PROBLEMS & REPORTS, SYNC CENTER IF THE MONITOR IS PLUG AND PLAY DEVICE LIKE TOUCH SCREEN.
ROD
On my 1997 GMC sierra 4/4 the engine light is lit at all time I was tell it is a clog valve (help)
The first step in any check engine light is to get the compuetr scanned for codes. there are many auto part stores that will scan the codes for free and give you a printout with the codes, if you get the codes i can help you find the problem bettter. good day.
I have a whirlpool sf325lekq0 and it shows a code of PF on the dispaly and beeps. What does the PF indicate?
That would indicate a power failure you can press the clear off nutton and it should get rid of this PF displayed
2helpful
Sir i have JXD661 mp4,mp3 player but it cannot on when i press only green light on but no dispaly,pls give me solution.reset button also press but no responce
2helpful
2answers
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
Cmos problem
checkcu fix jumper in its 1-2 position
also refix ram
also check dispaly cable is fixed properly.
Help me
delete everything on the device as there is prob a corupt file that the computer cant read
Coil pack problem
i give you a straight tip your car is a compuetr conrtole system,u need a wiring diagram check everythingthen ,chek ground,check connection to ground,wiring terminal to ecu then_______got it
4answers
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Top Pine Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pine Technology Computer and Internet Expert? Answer questions, earn points and help others
