Looking to find my Dell V515w Hard Drive inside printer, I would like to know what it looks like and how to take apart printer to find it?
On the off chance that your Dell Printer isn't working properly or you're facing particular issues setting up your printer and you need capable master authorities, this is the time when we step in.
Dell Printer Customer Care Phone Number +1-833-260-7367
we have given you the best dell customer administration. exactly when you standing up to any specific issues in dell printers. If you and your sidekicks need and approach the best for dell printer bolster administration, you simply need to
https://easysupportnumber.blogspot.com/
SOURCE: my printer dell V515w just
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
SOURCE: Need to adapt Dell V515w to Mac
Hi Philip,
Just download your printers Mac drivers here and run setup for printer software installations on your PC.
Hope this helps.Thanks!
Please rate this answer.
