Sylvania SMPK 8099 Video MP3 Player Logo
Dylan Stanley Posted on Jan 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a Sylvania SMPK8099 and charged it for 3 hours and it still wont turn on
I'ved tried everything in the manual and it still wont work
Anonymous
Level 3:
  • Sylvania Master 32,281 Answers
  • Posted on Jan 07, 2013
Anonymous
Sylvania Master
Level 3:
Answers
32281
Questions
Helped
7913581
Points
102259
Try charging it overnight and if it still does not work return it to the shop where you purchased it for a replacement or refund as it wouls be under warranty.
Download utilities installation for sylvania SMPK8099
Check out Google and Ebay - might be available there. Alternatively, go to the mfr's site and see what they have to offer.
It doesn't even turn on
Try charging the player for four or more hours.
Sylvaniasmpk8099 wont turn on
Check the fuse in the adapter cable .
Adjust volume on smpk8099
Hold down the Pause/Play button until the volume pops up at the bottom.
MP4 SYLVANIA SMPK8099 8GB WILL NOT TURN ON
If it won't turn on then CHARGE IT!!! That's one way.....???
1helpful
3answers
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
I just received a sylvania SMPK8099 MP3 player and I'm trying to figure it all out.. I can't seem to get it to charge the battery. I've followed the instruction but it doesn't seem to be...
Sylvania mp3 player lost your cd here is the softwear for you to download
You can try an overnight charge. If that fails, the usual remedy is to return the device for service under warranty. Failure to accept a charge suggests a bad battery. I find no DIY instructions identifying a change of its battery. As to the driver failure, this is likely a compatibility issue. You have not identified your operating system. The user manual may identify which OS the device is compatible with. Try installing the driver with the device disconnected, reboot, plug in the device, reboot again. I believe the device worked with Windows 7 or XP but am uncertain if it worked with other OS.
I just bought the sylvania model sytabex7 and it wont turn on... just has a little tiny flashing dot in the corner
Your battery is dead. Leave it to charge for a minimum of 4 hours, then turn it back on.
Disney MixMax player... JUST bought this device. I installed the software CD, but that is JUST for the online/media storage component... I plugged it into the computer & computer wont recognize it at...
The manual indicates that it should show charging as soon as connected, and takes three hours to charge.
I have found that on some devices, this does not happen, and it takes a few minutes for the device to get enough charge into the battery to start up. This especially from new, or if left for a long while.
Try giving it a long charge, six hours is recommended by some manufacturers, using the same type of battery.
leave your computer on, it won't hurt it, as the USB ports, only supply power when it's on.
If it does not work then, as you have only just bought it, take it back.
Top Sylvania Audio Players & Recorders Experts
Aron
 Grubhead
Grubhead
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
