The
Steps for Newer Style Console Calibration: Locate
the calibration area on the rear or underside of the console (a
hole, near the console's center, that goes through to the
electronics board. (This hole should not have a screw
in it.) Insert a pencil
(eraser end), into the hole and feel around for the cal button
(will click when pressed). Press the
button 2 times (with the pencil eraser). The first click
should show CL11 in the console, the second click should
show CL21. If the process
was done correctly, and CL21 appears in the console, you are in
"calibration mode." The next few steps consists
of pressing buttons on the console and observing settings.
This will not require any other tools. Press ENTER.
CL22 should display in the TIME window and (??) in
the SPEED window. Press ENTER. CL23
should display in the TIME window and (??) in the SPEED window. Press ENTER. CL24
CL25 should display in the TIME window and (??) in the
CL26 should display in the TIME window. You should
then see the letter "E."
Press ENTER. You
should see "SS" or "55" in the console.
Push the
STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill. Push the ENTER
button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
When the belt stops,
the incline should self test by raising to its
highest incline position, then lowering back down to its lowest
position. Once the incline
test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is
ready for use. If
the letter "F" appears in the SPEED or INCLINE window when
the power button is pressed 2 times, the treadmill is
indicating a failure somewhere either in the SPEED or INCLINE
(depending on the window the "F" appeared in).
The
SCR lower board
is designed with diagnostic LED lights. The LED's are color coded
according to their
specific function. Green indicates a properly operating treadmill;
the green lights should always be
ON when power is supplied to the treadmill. Yellow indicates a
treadmill function. Red indicates a treadmill
malfunction. Here is a list of each LED and what it signifies: MOTOR
(yellow) -
The MOTOR LED illuminates when dc (direct current) voltage is sent to
the drive motor.
The LED gets brighter when the dc output is increased. RLC
(yellow) -
The RLC (R = Reactance / L = Inductance / C = Capacitance) LED
illuminates when the
filtering system is properly working. The filtering system includes
the capacitor and filter choke. If there
is a short in either component then the RLC light will not come on. DN
& UP (yellow) -
The DN and UP LED lights tell us if the elevation DN and UP relays
are functioning
properly. When the LED lights, it tells us that the relay has
energized and is sending high voltage
(110vac or 220vac) to the elevation motor. AC
PWR (green) -
The AC PWR (Alternating Current Power) illuminates when AC line
voltage is delivered
to the treadmill. It then passes through the in-line fuse
(110)/s(220) and lights the AC PWR LED. +12V
(green) -
When the proper AC voltage is delivered to the treadmill, passes
through the in-line fuse/s,
through the full wave bridge rectifier (changes AC to DC), through
the transformer (steps down This
the board LED, who control the DC to +12vdc) then the +12V LED
lights. 2)
The RELAY board
according to their
malfunction. Here is a list of each LED and what it signifies: AC
PWR (green) -
(110)/s(220) and lights the AC PWR LED. VDC
(green) -
The VDC LED will light when it receives DC voltage from the DC power
supply. DN
& UP (yellow) -
are functioning
(110vac or 220vac) to the elevation motor. UPSW
(green) -
This LED will illuminate when the low voltage dc is delivered from
the upper display board
to the elevation UP relay. This low voltage dc is what energizes the
coil of the relay. DNSW
(green) -
to the elevation DOWN relay. This low voltage dc is what energizes
the coil of the relay. BELTSW
(green) -
the upper display
board to the belt (motor start) relay. This low voltage dc is what
energizes the coil of the relay. SPD
(yellow) -
The SPD LED flashes on and off (relative to speed) when the speed
sensor is operating
properly. PWM
(yellow) -
This LED will light when the upper board is sending a speed signal to
the PWM. Both
the PWM LED and BELTSW LED must be lit for belt movement. Step 1:
please see this test and fix it. God bless you
Step 2:
signal for Main Motor+Elevation Motor. You must see, the
LED DN+ UP( both will be Lit) in any position down or Up.
Finally
this this Relay Board, the Each Led will be Lit, for any Relai
control for DN down, or UP for elevation Motor. You must clean
contact of the Relay with Special Spray(Radio Schack).
With
this you must fix it.
Step 3:
please lube the elevation motor, shaft, and gear, and adjust the POT for RPM, and see what happen. see the diagram + block diagram attached for troubleshooting and fix it.
God bless you
