You will need to replace the igniter. Here is the part to order.http://click.linksynergy.com/fs-bin/clic...You will need to replace the igniter. Here is the part to order. http://click.linksynergy.com/fs-bin/click?id=n5dODaS6Jdw&subid=0&offerid=92089.1&type=10&tmpid=2111&RD_PARM0=http%253A%252F%252Fwww.appliancepartspros.com%252Ffrigidaire-igniter-318177710-ap2129143.html&RD_PARM1=http&RD_PARM2=%253A%252F%252Fwww.appliancepartspros&RD_PARM3=.com%252Ffrigidaire-igniter-318177710-ap2129143.html
You can't post conmments that contain an email address.
Check that the burners are clean. There is a small hole near where the spark electrode is and it often blocks. That hole directs a small jet of gas at the igniter electrode. Make sure the aluminum bezel below the burner is clean as it is part for the electrical circuit. Make sure the spark electrode hasn't moved away from the burner. Make sure the electrode wire is attached.
You say it says propane, but it is on natural gas. I hope the jets conversion was done :>) It is a mighty fine stove, I am a chef!
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts. http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Will have to ask some basic questions first. How old is the stove? What is the entire model # from the sticker on the unit? Is this LP or natural gas? Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean). Make sure that the black caps are on top of the burners and seated properly or they will not lite. Let me know what you find.
Kenmore Elite Gas Slide-in Range Model No. 790.3107
