I have an 8 GB iPod touch that is now disabled because I can't remember the 4 digit code. The message on the iPod's screen says, 'iPod is disabled. Connect to iTunes.' The computer that I originally used with it has recently crashed. When I installed iTunes on my new computer and connected the iPod Touch to it, a message appears saying, 'Can't connect iPod, please enter 4 digit code.' What is my next course of action?
my ipod 8gb say disable when i hook it up to the itunes it ask for the four diget passcode.
I have the same problem with the Ipod touch is disabled and it says to enter a 4 digit passcode.I have the same problem with the Ipod touch is disabled and it says to enter a 4 digit passcode.
1. Keep the power and home buttons pressed until the "Connect to iTunes" screen comes and restore (everything will be erased). or 2. Ssh your iphonego to th path mobile/Library/Preferences/delete com.apple.springboard.plistoff and on your iPhone (MAY need to be jailbroken, not entirely sure).
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected] or add me on Skype: ebayseller.ca
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
I know a solution for your problem but I must inform you firstly that it will erase all data in your iPod touch including the jailbreak, in case it's jailbroken.
If you decided to continue, just click here to see the step by step guide on what you need to do.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Go on to itunes and plug your mp3 in to your computer and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
if you need any further help let me know. Good Luck
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
i Pod is disabled connect to the i Tunes it message occurred when i connect to the i Tunes
and I forgot my password nd now my scren is locked
